Hi Jamessimm,
Thanks for sharing your setup and the challenges you’re facing. You’re dealing with a pretty typical asynchronous-payment scenario, and I think the approach you’ve taken is sound. Below are some thoughts, confirmations of what works, and a few suggestions to strengthen the flow and avoid edge-cases.
So far - this matches recommended practices for asynchronous payment flows + external gateway + webhooks.
Recommended enhancements & safeguards:
PaymentPending = true flag, prevent further changes to line items or shipping after payment call)Wait for webhook.
On success → convert cart to order, unlock order, send downstream events.
On failure or timeout → revert cart lock, notify user, allow retry or alternative payment.
Hope this will helps you!
Hi Sunil,
Thanks for the reply, this was posted a while ago and we've solved the issues since then.
We ended up with a flow that:
A lot of your suggestions are exactly what we implemented, so good to have that validated.
Thanks.
Great to hear that, and thanks for the update!
Your final flow sounds solid - converting the cart to an order in a “pending” state is a reliable pattern, and handling both webhook outcomes (success/failure) via state transitions is exactly how most async-payment platforms operate.
Glad to know the suggestions aligned with what you implemented.
Sorry for the long post, but got a "fun" problem to solve:
Our client uses CMS 12 / Commerce Connect 14 + Adyen payments (via the drop-in component).
As it stands:
The original problem:
Work done so far:
The problem I need to solve is:
Been researching this and everything seems to be geared towards a "synchronous" payment flow where you know the payment succeeded before placing the order.
Has anyone dealt with anything like the above?
