Probably a group access issue - the config is likely different between the two environments. ("VisitorGroupAdmins" missing?)
See https://docs.developers.optimizely.com/content-management-system/docs/configuring-personalization
I think Personalize command is hide because:
services.Configure<ExternalApplicationOptions>(options => options.OptimizeForDelivery = true)
services.UseCmsLite()
In Dojo js file, this command is added if LimitUI = false and SectionsVisibility.VistiorGroups = true
=> So you should remove those code lines to fix this issue
Hi Daman,
you can check in startup your ExternalApplicationOptions in startup & make its delivery True like this:-
services.Configure<ExternalApplicationOptions>(options => options.OptimizeForDelivery = true);
I hope this helps :-)
Do not see the persoanlize option on blocks in our Inte, PreProd, Prod environments but oddly enough, saying it in LOCAL:
In Intg/Prep/Prod environments:
In LOCAL (personalize option)
