Evaluate Promotions Fail for Redemption Limits
Hi there!
I recently migrated to the latest Commerce 14 version and an error started when applying for promotions using the Redemption Limits rules. If there is a value greater than zero in the Per registered user field, the promotion is never applied. It only works for unlimited redemptions.
The following image shows the configuration for a limited promotion:
This is part of the code I am using for evaluating promotions:
var inMemoryOrderGroup = new InMemoryOrderGroup(currentMarket, currencyCode);
inMemoryOrderGroup.OrderLink = cart.OrderLink;
foreach (ILineItem lineItem in cart.GetFirstForm().GetAllLineItems())
	inMemoryOrderGroup.AddLineItem(lineItem);
inMemoryOrderGroup.GetFirstForm().CouponCodes.Add(couponCode);
rewards = ServiceLocator.Current.GetInstance<IPromotionEngine>().Run(inMemoryOrderGroup);
if (rewards.Any())
	// rewards is empty
Is there something else I need to consider in the new Commerce 14 version to evaluate promotions? (The same code was working in version 12.15)
#300643
Apr 24, 2023 13:38
Is this current customer logged in? Also how do you create "inMemoryOrderGroup" ?
#300688
Apr 25, 2023 9:24
Yes, it is the current customer who logged in.
The `InMemoryOrderGroup` is created using the current market (`ServiceLocator.Current.GetInstance<ICurrentMarket>().GetCurrentMarket()`) and current currency code (`ServiceLocator.Current.GetInstance<ICurrencyService>().GetCurrentCurrency().CurrencyCode`) then I add lines using the `AddLineItem` method.
#300694
Apr 25, 2023 13:26
What's about the CustomerId of the InMemoryOrderGroup?
#300695
Apr 25, 2023 13:30
Hi Quan,
Thank you for your help. I set the CustomerId value in the InMemoryOrderGroup object and worked! This is the new code:
inMemoryOrderGroup.CustomerId = cart.CustomerId;
if (rewards.Any())
	// rewards contain elements
#300839
Apr 27, 2023 16:21
