Customers UI: Organization Contacts displaying only max 10 contacts.
Hi, we are currently facing issue in Customers UI. We have organizations that are assign to more then 10 contacts but when going to Organization detail -> Contacts there are only first 10 contacts displayed without any pagination. When click on Add, Add contacts modal displays with all Contacts and more then 10 Contacts is correctly checked. But in Organization Contacts there is displayed only 10 Contacts (see screen)  Is this intentional? Is there a way to display more contacts there or display pagination? Is this a bug?
#296218
Feb 09, 2023 9:13
It is definitely not intentional. I tested and it works fine on 14.10. let me check on 14.9 - it could be a bug that was fixed
#296253
Feb 09, 2023 13:14
Can confirm it works with 14.9, do you see errors in the browser console?
#296254
Feb 09, 2023 13:20
Quan Mai-
(I am working with Petr on this)....
I want to clarify, this is NOT the main Contacts tab, but the contacts tab WITHIN the Organization that seems to be missing pagination when there are more than 10 contacts in an org.
I did confirm there are no errors in the console and we are running 14.9.
#296267
Feb 09, 2023 14:52
Ah thanks for your clarification. I can confirm it does not work with 14.10. I will file a bug to Commerce development team. thanks for bringing this into our attention
#296271
Feb 09, 2023 15:00
- Feb 09, 2023 15:03
The bug is COM-16781, but it is currently not visible to public
Quan Mai-
i had not tried until just now, but Addresses has the same problem and only show first 10, and I suspect child Organizations will too:
There are 12 addresses added here:
#296278
Feb 09, 2023 15:43
- Feb 09, 2023 16:33
will note this, thanks
