Here is the stack trace:
Unhandled exception. System.ArgumentNullException: Value cannot be null. (Parameter 'connectionString')
at Microsoft.EntityFrameworkCore.Utilities.Check.NotEmpty(String value, String parameterName)
at Microsoft.EntityFrameworkCore.SqlServerDbContextOptionsExtensions.UseSqlServer(DbContextOptionsBuilder optionsBuilder, String connectionString, Action`1 sqlServerOptionsAction)
at Microsoft.Extensions.DependencyInjection.OpenIDConnectServiceCollectionExtensions.<>c__DisplayClass1_0`1.<AddOpenIDConnect>b__1(IServiceProvider sp, DbContextOptionsBuilder options)
at Microsoft.Extensions.DependencyInjection.EntityFrameworkServiceCollectionExtensions.CreateDbContextOptions[TContext](IServiceProvider applicationServiceProvider, Action`2 optionsAction)
at Microsoft.Extensions.DependencyInjection.ServiceLookup.CallSiteVisitor`2.VisitCallSiteMain(ServiceCallSite callSite, TArgument argument)
at Microsoft.Extensions.DependencyInjection.ServiceLookup.CallSiteRuntimeResolver.VisitCache(ServiceCallSite callSite, RuntimeResolverContext context, ServiceProviderEngineScope serviceProviderEngine, RuntimeResolverLock lockType)
at Microsoft.Extensions.DependencyInjection.ServiceLookup.CallSiteRuntimeResolver.VisitScopeCache(ServiceCallSite callSite, RuntimeResolverContext context)
at Microsoft.Extensions.DependencyInjection.ServiceLookup.CallSiteVisitor`2.VisitCallSite(ServiceCallSite callSite, TArgument argument)
at Microsoft.Extensions.DependencyInjection.ServiceLookup.CallSiteRuntimeResolver.VisitConstructor(ConstructorCallSite constructorCallSite, RuntimeResolverContext context)
at Microsoft.Extensions.DependencyInjection.ServiceLookup.CallSiteRuntimeResolver.Resolve(ServiceCallSite callSite, ServiceProviderEngineScope scope)
at Microsoft.Extensions.DependencyInjection.ServiceLookup.DynamicServiceProviderEngine.<>c__DisplayClass2_0.<RealizeService>b__0(ServiceProviderEngineScope scope)
at Microsoft.Extensions.DependencyInjection.ServiceProvider.GetService(Type serviceType, ServiceProviderEngineScope serviceProviderEngineScope)
at Microsoft.Extensions.DependencyInjection.ServiceLookup.ServiceProviderEngineScope.GetService(Type serviceType)
at Microsoft.Extensions.DependencyInjection.ServiceProviderServiceExtensions.GetRequiredService(IServiceProvider provider, Type serviceType)
at OpenIddict.EntityFrameworkCore.OpenIddictEntityFrameworkCoreApplicationStoreResolver.Get[TApplication]()
at OpenIddict.Core.OpenIddictApplicationCache`1..ctor(IOptionsMonitor`1 options, IOpenIddictApplicationStoreResolver resolver)
at System.RuntimeMethodHandle.InvokeMethod(Object target, Span`1& arguments, Signature sig, Boolean constructor, Boolean wrapExceptions)
at System.Reflection.RuntimeConstructorInfo.Invoke(BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture)
at Microsoft.Extensions.DependencyInjection.OpenIddictCoreExtensions.<>c.<AddCore>b__0_0(IServiceProvider provider)
at Microsoft.Extensions.DependencyInjection.ServiceProviderServiceExtensions.GetRequiredService[T](IServiceProvider provider)
at EPiServer.OpenIDConnect.Internal.OpenIDConnectApplicationHostedService.RegisterApplication(IServiceScope scope)
at EPiServer.OpenIDConnect.Internal.OpenIDConnectApplicationHostedService.StartAsync(CancellationToken cancellationToken)
at Microsoft.Extensions.Hosting.Internal.Host.StartAsync(CancellationToken cancellationToken)
at Microsoft.Extensions.Hosting.HostingAbstractionsHostExtensions.RunAsync(IHost host, CancellationToken token)
at Microsoft.Extensions.Hosting.HostingAbstractionsHostExtensions.Run(IHost host)
at CommerceSite.Program.Main(String[] args) in C:\Projects\CommerceSite\commerce-site\CommerceDigital\Program.cs:line 11
We have OpenIdConnect configured with Azure AD. Could it be that I need to create this user in Azure AD instead of in Startup? Is it this that I've mis-understood perhaps?
I've removed the code above and in the Startup class I have included AddOpenIDConnectUI to be able to add the application manually within the backoffice.
BUT, when I add the credentials and click "Save", nothing happens. The user I am logged in with has the "WebAdmins" role, so permissions should not be an issue.
Interestingly I get the following error when clicking "Save":
fail: Microsoft.AspNetCore.Diagnostics.DeveloperExceptionPageMiddleware[1]
An unhandled exception has occurred while executing the request.
System.InvalidOperationException: Unable to resolve service for type 'OpenIddict.Abstractions.IOpenIddictApplicationManager' while attempting to activate 'EPiServer.OpenIDConnect.UI.Applications.Internal.ApplicationsController'.
at Microsoft.Extensions.DependencyInjection.ActivatorUtilities.GetService(IServiceProvider sp, Type type, Type requiredBy, Boolean isDefaultParameterRequired)
at lambda_method3425(Closure , IServiceProvider , Object[] )
at Microsoft.AspNetCore.Mvc.Controllers.ControllerActivatorProvider.<>c__DisplayClass7_0.<CreateActivator>b__0(ControllerContext controllerContext)
at Microsoft.AspNetCore.Mvc.Controllers.ControllerFactoryProvider.<>c__DisplayClass6_0.<CreateControllerFactory>g__CreateController|0(ControllerContext controllerContext)
at Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker.Next(State& next, Scope& scope, Object& state, Boolean& isCompleted)
at Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker.InvokeInnerFilterAsync()
--- End of stack trace from previous location ---
at Microsoft.AspNetCore.Mvc.Infrastructure.ResourceInvoker.<InvokeNextResourceFilter>g__Awaited|25_0(ResourceInvoker invoker, Task lastTask, State next, Scope scope, Object state, Boolean isCompleted)
at Microsoft.AspNetCore.Mvc.Infrastructure.ResourceInvoker.Rethrow(ResourceExecutedContextSealed context)
at Microsoft.AspNetCore.Mvc.Infrastructure.ResourceInvoker.Next(State& next, Scope& scope, Object& state, Boolean& isCompleted)
at Microsoft.AspNetCore.Mvc.Infrastructure.ResourceInvoker.InvokeFilterPipelineAsync()
at Microsoft.AspNetCore.Mvc.Infrastructure.ResourceInvoker.<InvokeAsync>g__Awaited|17_0(ResourceInvoker invoker, Task task, IDisposable scope)
at Microsoft.AspNetCore.Routing.EndpointMiddleware.<Invoke>g__AwaitRequestTask|6_0(Endpoint endpoint, Task requestTask, ILogger logger)
at Microsoft.AspNetCore.Authorization.Policy.AuthorizationMiddlewareResultHandler.HandleAsync(RequestDelegate next, HttpContext context, AuthorizationPolicy policy, PolicyAuthorizationResult authorizeResult)
at Microsoft.AspNetCore.Authorization.AuthorizationMiddleware.Invoke(HttpContext context)
at Microsoft.AspNetCore.Authentication.AuthenticationMiddleware.Invoke(HttpContext context)
at SixLabors.ImageSharp.Web.Middleware.ImageSharpMiddleware.Invoke(HttpContext httpContext, Boolean retry)
at Microsoft.AspNetCore.Diagnostics.DeveloperExceptionPageMiddleware.Invoke(HttpContext context)
Good Morning,
So I now made one small step forward. In the Startup, I have updated the following call:
services.AddServiceApiAuthorization(OpenIdConnectOptionDefaults.AuthenticationScheme);
So that it now reads:
services.AddServiceApiAuthorization(OpenIdConnectDefaults.AuthenticationScheme);
And now I get the following error when querying a ServiceApi endpoint:
"message": "User is not authorized for this request."
Of course I made the query using an access token from our Azure AD.
So now is the question, what am I missing? The error in my previous message still exists when trying to add an Application (which I believe is likely the missing link here).
/Stephen
We are using the client_credentials flow, so we aquire a token using the clientId and clientSecret
For the next person who encounters this problem. We managed to solve this by ensuring that we have the following setup in out Startup class.
Its worth poiniting out that our OpenId configuration uses idToken ResponseType which differs from the standard/Foundation configuration of OpenId.
The following steps were crucial in getting it to work for us. And by "working" I mean that the application would start up and we could assign the SiteUser created for ServiceApi ReadAccess and WriteAccess.
Hopefully this will help someone else with the same problem!
services.AddCmsAspNetIdentity<SiteUser>(o =>
if (string.IsNullOrEmpty(o.ConnectionStringOptions?.ConnectionString))
o.ConnectionStringOptions = new ConnectionStringOptions
Name = "EcfSqlConnection",
ConnectionString = _configuration.GetConnectionString("EcfSqlConnection")
var azureSection = _configuration.GetSection("AzureAD");
services.AddAuthentication(options =>
options.DefaultAuthenticateScheme = "azure-cookie";
options.DefaultChallengeScheme = "azure";
.AddCookie("azure-cookie", options =>
options.Events.OnSignedIn = async ctx =>
if (ctx.Principal?.Identity is ClaimsIdentity claimsIdentity)
// Syncs user and roles so they are available to the CMS
var synchronizingUserService = ctx
.HttpContext
.RequestServices
.GetRequiredService<ISynchronizingUserService>();
await synchronizingUserService.SynchronizeAsync(claimsIdentity);
.AddOpenIdConnect("azure", options =>
azureSection.Bind(options);
options.SignInScheme = "azure-cookie";
options.SignOutScheme = "azure-cookie";
options.ResponseType = OpenIdConnectResponseType.IdToken;
options.UsePkce = true;
options.Scope.Clear();
options.Scope.Add(OpenIdConnectScope.OpenIdProfile);
options.Scope.Add(OpenIdConnectScope.OfflineAccess);
options.Scope.Add(OpenIdConnectScope.Email);
options.MapInboundClaims = false;
options.TokenValidationParameters = new TokenValidationParameters
RoleClaimType = ClaimConstants.Roles,
NameClaimType = "preferred_username",
ValidateIssuer = false
options.Events.OnRedirectToIdentityProvider = ctx =>
// Prevent redirect loop
if (ctx.Response.StatusCode == 401) ctx.HandleResponse();
return Task.CompletedTask;
options.Events.OnAuthenticationFailed = context =>
context.HandleResponse();
context.Response.BodyWriter.WriteAsync(Encoding.ASCII.GetBytes(context.Exception.Message));
services.AddCommerce()
.AddFind()
.AddMvc();
services.AddMoreServices();
// such as session
services.AddSession();
// etc., etc.
services.ConfigureTinyMce()
.ConfigureKestrel();
var serviceApiSection = _configuration.GetSection("ServiceApi");
services.AddOpenIDConnect<SiteUser>(
useDevelopmentCertificate: true,
signingCertificate: null,
encryptionCertificate: null,
createSchema: true,
options =>
var application = new OpenIDConnectApplication
Scopes = { ServiceApiOptionsDefaults.Scope }
serviceApiSection.Bind(application);
options.Applications.Add(application);
options.AllowResourceOwnerPasswordFlow = true;
options.AllowAnonymousFlow = true;
services.AddServiceApiAuthorization(OpenIDConnectOptionsDefaults.AuthenticationScheme);
services.AddOpenIDConnectUI();
If you are currious what we are binding, then our json config contains the following relevant settings (sensitive data removed):
"AzureAD": {
"Authority": "",
"ClientId": "",
"CallbackPath": "/signin-oidc"
"ServiceApi": {
"ClientId": "postman-client",
"ClientSecret": "postman"
Hello,
Hopefully an easy one here. I'm new to Service API and am trying to setup the service according to the docs:
https://docs.developers.optimizely.com/customized-commerce/v1.3.0-service-api-developer-guide/docs/installation-and-configuration
I have added the following code to the Startup class:
But upon starting the application I simply get an ArgumentNullException "Value cannot be null. (Parameter 'connectionString')"
Is the documentation still up to date here? What am I missing?
Regards, Stephen
