Only displays blocks "For this page" in in "Choose content" popup
Not sure when this happened but editors has noticed that you no longer can choose page from the page tree anymore on ContentAreas when selecting "Choose contentt" (Välj innehåll på svenska).
The workaround is of course to drag and drop the pagefrom the tree but I wonder if anyone knows when and why this was removed from the popup.
Images show what happens when you click "Välj innehåll" on an ContentArea that allows ArticleBlock and ArticlePage.
Regards
Linus
#340343
Sep 10, 2025 11:47
What version of CMS are you on?
#340382
Sep 11, 2025 18:27
#340389
Sep 12, 2025 5:25
Have you added any [AllowedTypes] or any custom validation on ContentArea?
#340402
Sep 12, 2025 19:43
I have like this:
[AllowedTypes(AllowedTypes = new[] { typeof(ArticlePage), typeof(ArticleBlock) })]
And I have the same behaviour in two different solutions.
I just want to know if anyone else has this behaviour, i'm not even sure if you used to be able to choose from page tree in the pop-up, but the editors working in Optimizely claim so.
Linus
#340422
Sep 15, 2025 6:40
FWIW, also on 12.33.3, and I can select pages in a content area -- I've got mine set up to allow StandardPage and Blocks (if it matters, this content type property is defined via UI, for a quick test):
#340432
Sep 16, 2025 22:00
Thank you for chiming in! Ok, so I guess there's something weird that I'm doing after all.
Linus
#340435
Sep 17, 2025 6:37
I found what was causing it. We had an CustomContentAreaEditor which for som reason broke the tree rendering. But it has nothing to the with the pop-up (i thought...) and there was no error in the conole or in backend.
Linus
#340459
Sep 19, 2025 10:08
