Edit Tabs: Different values for different users intermittently
We have run into a strange problem. When some users log into the CMS for editing they can see tabs that we have set to Administer (even tough they don't have that access level) and also the taborder is totally messed up.
When I as admin go to Settings -> Edit Tabs, then I see that sort index for most tabs is -1 and requires access level is read, but for some other admin the list is correct as it should be from code.
I have looked through the code and I can see that it first reads from DB, and there the settings are -1 for sort index and read for access level. It will then merge that with what we have defined in code, but it seems like this is not done for some!? users. I cannot see somewhere in code that user plays a part, so I don't understand why it differs.
We have 2 frontends and 1 db, but me and the other admin was on the same frontend and got different Tab-settings.
I'm trying to reproduce in local and test-environment, but I haven't figured out how this can happen.
I would need some help in figuring out how this can happen, if it is a configuration error on our end or something with our user-setup. Or is this a known problem?
#336408
Feb 04, 2025 9:02
