Error in SendEmailAfterSubmissionActor when accessing HttpRequestContext
After upgrade to .net 9 and CMS 12.32.2 we get an error when we are trying to read the HttpRequestContext. Forms are version 5.10.2
This is the code:
public class SendEmailAfterSubmissionActor : EPiServer.Forms.Implementation.Actors.SendEmailAfterSubmissionActor
    private readonly SmtpSettings _smtpSettings;
    private readonly PlaceHolderService _placeHolderService;
    private readonly SmtpClient _smtpClient;
    private readonly XhtmlRenderService _xhtmlRenderService;
    public SendEmailAfterSubmissionActor(SmtpSettings smtpSettings, PlaceHolderService placeHolderService, XhtmlRenderService xhtmlRenderService)
        _smtpSettings = smtpSettings;
        _placeHolderService = placeHolderService;
        _xhtmlRenderService = xhtmlRenderService;
        _smtpClient = new(_smtpSettings.Host, _smtpSettings.Port)
            DeliveryMethod = _smtpSettings.DeliveryMethod,
            PickupDirectoryLocation = _smtpSettings.PickupDirectoryLocation
    public override object Run(object input)
        if (!(Model is IEnumerable<EmailTemplateActorModel> emailTemplateActorModels) || !emailTemplateActorModels.Any())
            _logger.Debug("There is no collection of EmailTemplateActorModel for this actor to work.");
            return null;
        foreach (var actorModel in emailTemplateActorModels)
            SendMessage(actorModel);
        return null;
public void SendMessage(EmailTemplateActorModel emailTemplateActorModel)
   if (HttpRequestContext?.Form?.Files != null && HttpRequestContext.Form.Files.Count > 0)
And it gives me this error
Unexpected end of Stream, the content may have already been read by another component
I can watch the object in debug mode and Form is null, since it is a post I guess there should be a form available?
Does any know why this is happening?
Thanks!
/Kristoffer
#335985
Jan 23, 2025 12:13
Can you post the full stacktrace?
#335986
Jan 23, 2025 13:10
   at Microsoft.AspNetCore.WebUtilities.MultipartReaderStream.<ReadAsync>d__38.MoveNext()
   at System.Threading.Tasks.ValueTask`1.get_Result()
   at System.Runtime.CompilerServices.ValueTaskAwaiter`1.GetResult()
   at Microsoft.AspNetCore.WebUtilities.StreamHelperExtensions.<DrainAsync>d__3.MoveNext()
   at Microsoft.AspNetCore.WebUtilities.MultipartReader.<ReadNextSectionAsync>d__20.MoveNext()
   at Microsoft.AspNetCore.Http.Features.FormFeature.<InnerReadFormAsync>d__24.MoveNext()
   at Microsoft.AspNetCore.Http.Features.FormFeature.ReadForm()
   at Klaranatet.Web.Core.Infrastructure.EpiServerForms.SubmissionActors.SendEmailAfterSubmissionActor.SendMessage(EmailTemplateActorModel emailTemplateActorModel) in C:\Users\Utv2\Projects\Klaranatet.Web\Klaranatet.Web.Core\Infrastructure\EpiServerForms\SubmissionActors\SendEmailAfterSubmissionActor.cs:line 120
#335987
Edited, Jan 23, 2025 13:43
Hi Quan!
Did you find anyhing? Should I report a bug?
Thanks!
/Kristoffer
#336035
Jan 24, 2025 9:35
- Jan 24, 2025 9:51
No I haven't. Had no time to look into this, yet. Please contact our developer support service for further assistance
Hi Krisoffer,
It's a known bug of Opti form.
A temporary workaround is your actor need to implement ISyncOrderedSubmissionActor  and set the IsSyncedWithSubmissionProcess to true.
public class SendEmailAfterSubmissionActor: EPiServer.Forms.Implementation.Actors.SendEmailAfterSubmissionActor
    public override bool IsSyncedWithSubmissionProcess => true;
I know that, when implementing the ISyncOrderedSubmissionActor , the actors will run as synchronously instead of Async. But it is the only temporary solution while waiting for the issue to be fixed.
#336040
Edited, Jan 24, 2025 11:31
We have the same problem. Does anyone know when this will be solved from Optimizely?
#337696
Apr 03, 2025 7:20
A know bug since more than two months, it should be solved but maybe it isn't? Have you upgraded to latest version?
#337697
Apr 03, 2025 7:22
Yes latest is 5.10.4 on Forms so no update so far...
Another fun fact is that someone made me end up on the integration environment for World https://inte.world.optimizely.com/forum/developer-forum/cms-12/thread-container/2025/1/error-in-sendemailaftersubmissionactor-when-accessing-httprequestcontext/  Did not know this was possible :) So replyed twice on this post..
#337699
Apr 03, 2025 8:15
