EPiServer.CMS.TinyMce (4.3.0) 'styles' toolbar button renders label 'Paragraph'
Using EPiServer.CMS.TinyMce (4.3.0) I have the following configured. Why does the drop-down have a label of "Paragraph" and a tooltip of "Formats"?
I would like the dropdown to have a label of "Formats".
#308142
Sep 07, 2023 19:28
It's not the label of the dropdown, it's the first item/value in the dropdown, meaning your cursor is currently on a paragraph. If your cursor was on heading, I assume it would say 'Heading X'. The dropdown is called 'Formats' (hence the StyleFormats() method name in your code), that's why the tooltip says so as well.
See https://www.tiny.cloud/docs/tinymce/6/content-formatting/
#308182
Edited, Sep 08, 2023 0:37
Now I see that, thanks.
I'm upgrading from cms 11 to cms 12 and I see that TinyMce renamed things. I previously used 'styleselect' on the toolbar. I'm now using 'styles' and expected it to display 'Formats'.
Has the behavior changed in the latest TinyMce?
This is TinyMce in cms 11:
I feel this v6 TinyMce property doesn't really work right, because 'Paragraph' remains
#308207
Edited, Sep 08, 2023 14:19
Not sure you can remove the paragraph, at least one block element is probably needed. Did you try style_formats_merge? Maybe you can remove the block formats https://www.tiny.cloud/docs/tinymce/6/user-formatting-options/#block_formats
#308286
Sep 10, 2023 8:37
