Where to access logs / errors in Integration enviornment
What are all the ways to access logs / errors in Integration environment?
#306343
Aug 07, 2023 3:46
Hi Damon,
You can access the logs in the integration environment by logging into the paasportal and selecting your project you are looking to investigate.
Then once in the project select the troubleshoot tab. Within this area you can attach to the logs in real-time and see what is happening.
You can also access application insights within azure portal to get a more overview of site stability and performance.
Paul
#306346
Aug 07, 2023 6:34
