Hi Jeremy,
While I don't see any immediate issue with adding the settings (not sure if that is just for initial setup and configuration), would you not alternatively consider using the static file middleware to modify the headers upon images?
https://andrewlock.net/adding-cache-control-headers-to-static-files-in-asp-net-core/
This would be a more asp.net core approach and would not rely on the sixlabors package.
Alternatively you could enroll in the optimizely edge rendering image beta program and then you can render images at the edge.
https://www.optimizely.com/beta
Paul
You can set the caching headers for resized images when you call AddImageSharp within the startup.cs:
serviceCollection.AddImageSharp(options =>
options.OnPrepareResponseAsync = (context) =>
context.Response.Headers.CacheControl = new CacheControlHeaderValue
Public = true,
MaxAge = TimeSpan.FromDays(365)
}.ToString();
return Task.CompletedTask;
.Configure<AzureBlobStorageCacheOptions>(options =>
options.ConnectionString = connectionString;
options.ContainerName = containerName;
.ClearProviders()
.AddProvider<BlobImageProvider>()
.SetCache<AzureBlobStorageCache>();
Thanks Paul and Mark.
Mark, I like this approach for appending headers on optimised images. I was wondering on the best approach for media served from globalassets or contentassets folders that hasn't been optimised using ImageSharp library. As these folders are served outside of web root and are dynamically created we can't use the the PhysicalFileProvider (as the folder doesn't exist at runtime).
Hi Jeremy
For images which haven't gone through the resizing logic, you can set the cache duration directly in the appsettings.json as per this article: https://docs.developers.optimizely.com/content-management-system/docs/configuring-cms
"EPiServer": {
"Cms": {
"Media": {
"CacheControl": "public, max-age=31536000",
"ExpirationTime": "365.00:00:00"
You will also want your static JS / CSS files to cache too, but you do this by adding a CacheControl to the UseStaticFiles service extension:
app.UseStaticFiles(new StaticFileOptions
OnPrepareResponse = ctx =>
ctx.Context.Response.Headers.CacheControl = new CacheControlHeaderValue
Public = true,
}.ToString();
I am using the image optimisation package Baaijte.Optimizely.ImageSharp.Web where it specifically states on Github "DO NOT add other SixLabors.ImageSharp.Web settings!!".
I wish to modify the BrowserMaxAge to cache optimised CMS images for 1 year. Are there any concerns on this?
https://docs.sixlabors.com/articles/imagesharp.web/gettingstarted.html#setup-and-configuration
