Geta.NotFoundHandler.Optimizely.5.0.6 -> Geta.NotFoundHandler.Optimizely.5.0.7 Upgrade caused Redirection issues and caused site to crash
Geta.NotFoundHandler.Optimizely.5.0.6 -> Geta.NotFoundHandler.Optimizely.5.0.7 caused site to crash. Is there some setting in startup.cs or configuration that needed to change?
When I applied the above upgrade in our Dev environment it started to give timeout errors and site crashed.
Also on the local instance, it does not show all URLs, not able to scroll, is this a known issue
#306226
Aug 04, 2023 7:24
Hi Daman,
I can see that this release was to update a routing conflicts https://github.com/Geta/geta-notfoundhandler/issues/93.
It might help to raise your issue on github as this will go direct to the Geta team and they will be able to assist more.
We are using it without issue currently, so could also be a config issue.
Paul
#306227
Edited, Aug 04, 2023 7:58
