For a shortcut seeing a .aspx being generated?
For a shortcut, when is the follows generated?
After doing a package upgrade recently, we are seeing errors caused by the ‘LinkURL’ property when used with a link that has a shortcut setup, and it may be tied to one of the upgrades EpiServer.CMS.Core 12.15.1 made to the Episerver package.  Going back to the package version upgrade, the following release note on the Optimizely website (https://world.optimizely.com/documentation/Release-Notes/) might be relevant as it affects the same UrlResolver (which is called within the IUrlHelper.ContentUrl method) that is causing our issue..
Anyone experience something similar?
#307621
Aug 29, 2023 6:50
Hi Daman,
I haven't experienced this myself, however I am wondering if this is a bug that needs report to Optimizely here?
Is there steps to reproduce this? I will try if there are steps to reproduce.
Paul
#307623
Aug 29, 2023 9:19
