Upgrade to 12.19 and Tiny 4.2 gives console errors?
I just upgraded from CMS 12.14.0 to 12.19.0 and CMS.TinyMCE from 3.3.3 to 4.2.0 and now I get these errors in the console:
SyntaxError: Unexpected token '<'
    at dojo.fromJson (dojo.js:15:82234)
    at Object.json (dojo.js:15:120242)
    at _497 (dojo.js:15:123066)
    at _2cd (dojo.js:15:73012)
    at _2cb (dojo.js:15:72704)
    at resolve.callback (dojo.js:15:73525)
    at dojo.js:15:125114
    at _2f2 (dojo.js:15:75368)
    at _2ec (dojo.js:15:75232)
    at _2f1.resolve (dojo.js:15:76693)
Uncaught SyntaxError: Unexpected token '<' (at plugin.min.js:2:1)
plugin.min.js is located in the folder: /EPiServer/EPiServer.Cms.TinyMce/4.2.0/ClientResources/tinymce/plugins/imagetools/plugin.min.js
Any ideas?
Thanks!
/Kristoffer
#301899
Edited, May 16, 2023 8:18
Hi Kristoffer,
Firstly did you check if this version is compatible with CMS 12.19.0 after that can you re-install it? May be it is not been installed properly or something.
#301901
May 16, 2023 9:15
Well the Episerver.CMS 12.19.0 has a direct dependency to CMS.TinyMCE 4.2 so I guess there should not be a problem.
looks like imagetools are no longer for free, could that have something to do with it?
Thanks!
#301904
May 16, 2023 9:35
Wild guess: The server actually returns an error page in place of the plugin.min.js. Check the browser dev tools if you can see the response there, it might tell you more about what the error is.
#301909
May 16, 2023 10:02
Magnus, that is a great guess! Clicking on the link actually gives me a html page and not the actual script. I will dig deeper. Thanks!
#301914
May 16, 2023 10:13
They were actually 404 errors and removing these Tiny plugins from my configuration fixed the issue:
   imagetools
   paste
   spellchecker
Thanks all for your help!
/Kristoffer
#301922
May 16, 2023 11:47
Just fyi re: those TinyMCE plugins:
Spellchecker plugin:
EPiServer.CMS.TinyMce 4.x and above have the spellchecker built into TinyMCE. You do not need to install Spellchecker for TinyMCE 4.x; just add the following code in startup.cs to enable spellchecker:
services.AddTinyMce().AddTinyMceSpellChecker();
Via: https://docs.developers.optimizely.com/content-management-system/docs/optimizely-spellchecker-for-tinymce
Paste
See recent updates here: https://world.optimizely.com/documentation/Release-Notes/ReleaseNote/?releaseNoteId=CMS-27270
#302176
May 22, 2023 15:08
