Getting 500 error page after logging in to CMS, without any error log
I'm in the middle of upgrading from 11 to 12, and I'm encountering a 500 error page after logging into the CMS, but can't find the actual error message anywhere, and can't turn the generic error page off.
While a lot of things aren't working yet, I managed to fix all compilation errors and got the CMS running for the first time. The first issue, is that after logging in on "util/Login", I'm redirected to to root page instead of /episerver/cms. Is there a configuration for that?
When I manually go to /episerver/cms after logging in, the CMS seems to load fine. After a second or two, it suddenly switches to this:
Weirdly though, I had no issues last week and the CMS was usable to the extent that I upgraded the solution for.
But now, I get this. There is not a single error message in the logs, nothing in the Windows Event Viewer (if that is even relevant anymore), and I have also enabled the developer exception page in my startup. I'm really running out of ideas how to view the actual error message.
There is a warning about a missing module: The modules finder couldn't find a directory at '/EPiServer/episerver-telemetry-ui'. Could that in any way be relevant? I can't seem to find anything online or in the code that references this.
If it helps, here is my Startup:
public class Startup
        private readonly IConfiguration _configuration;
        private readonly IWebHostEnvironment _webHostEnvironment;
        public Startup(IConfiguration configuration, IWebHostEnvironment webHostEnvironment)
            _configuration = configuration;
            _webHostEnvironment = webHostEnvironment;
        public void ConfigureServices(IServiceCollection services)
            services.AddMvc();
            services.AddSession();
            services.AddRazorPages();
            services.AddHttpContextAccessor();
            services.AddCms();
            services.AddCmsAspNetIdentity<ApplicationUser>();
            services.AddCommerce();
            services.AddFind();
            services.AddSitemaps();
            services.AddSitemapsCommerce();
            services.AddNotFoundHandler(o =>
                var connectionString = _configuration.GetSection("ConnectionStrings")["EPiServerDB"];
                o.UseSqlServer(connectionString);
                o.HandlerMode = FileNotFoundMode.On;
                o.Logging = LoggerMode.On;
                o.LogWithHostname = false;
            services.AddOptimizelyNotFoundHandler(o =>
                o.AutomaticRedirectsEnabled = true;
                o.AddOptimizelyCommerceProviders();
            services.ConfigureApplicationCookie(options =>
                options.LoginPath = "/util/Login";
            if (_webHostEnvironment.IsDevelopment())
                services.AddAdminUserRegistration(opt =>
                    opt.Behavior = EPiServer.Cms.Shell.UI.RegisterAdminUserBehaviors.Enabled;
        // This method gets called by the runtime. Use this method to configure the HTTP request pipeline.
        public void Configure(IApplicationBuilder app, IWebHostEnvironment env)
            if (env.IsDevelopment())
                app.UseDeveloperExceptionPage();
            app.UseStaticFiles();
            app.UseRouting();
            app.UseAuthentication();
            app.UseAuthorization();
            app.UseSession();
            app.UseNotFoundHandler();
            app.UseOptimizelyNotFoundHandler();
            app.UseEndpoints(endpoints =>
                endpoints.MapContent();
                endpoints.MapRazorPages();
#301358
Edited, May 08, 2023 11:24
So apparently this happens when there is no license activated for the local site... I had to go to /EPiServer/EPiServer.Cms.UI.Admin/default#/Configurations/ManageSites and activate it, and now the error disappeared.
#301360
May 08, 2023 14:34
