Add MenuItem to the Admin -> Administer Users
I've found the documentation for adding MenuItems:
https://docs.developers.optimizely.com/content-management-system/docs/adding-and-configuring-menu-items#extend-the-user-settings-menu-using-menu-provider
How ever. How do add a menu item for the Admin > Administer Users -> [USER]?
Which path is this? "/global/..."
In the old CMS 11.17.x you did this:
[GuiPlugIn(DisplayName = "Carts",
               Description = "User's carts",
               Area = PlugInArea.SidSettingsArea, Url = "~/UI/PlugIns/UserCart.ascx")]
#301057
Edited, May 02, 2023 8:39
Manoj Kumawat - May 02, 2023 9:10
Can you try with /global/cms/admin/?
Carl S - May 02, 2023 9:23
But how do I get the current user in the Path? :)
/global/cms/admin/[USERNAME]?
Carl S - May 02, 2023 9:35
/global/cms/admin/ did nothing - nothing got added anywhere.
Manoj Kumawat - May 02, 2023 11:14
Doing that will replace it with existing Admin menu item.
You should try instead "/global/cms/admin/mycustommenu" so that it extends within the admin menu and it should appear.
Take a look at this blog post - https://world.optimizely.com/blogs/mark-stott/dates/2021/8/extending-the-admin-interface-in-optimizely-cms-12/
However, I am unsure if you could add a sublevel item beneath the existing subitem.
- May 10, 2023 7:59
Thanks for the plug :)
#301456
May 10, 2023 8:04
