Using LDAP for editor mode authentication
TW
TW
Optimizely
I'm working on adding authentication in an Alloy project before adding it to our main project, and am trying out using System.DirectoryServices.Protocols for the connection to our on-prem LDAP provider.
Problem is, when trying to log in the only events that register are to the default SQL-server for the default admin account.
How do I go about telling the Alloy project not to use that at all and just go to another auth scheme? I've read a lot of documentation and it's still not especially clear to me how to do this.
#300886
Edited, Apr 28, 2023 10:18
Hi TW
Optimizely has documentation for how to enable Mixed-mode authentication (see link below). The docs describe how you can change the default scheme which you should be able to enable to use your LDAP provider.
Mixed-mode authentication (optimizely.com)
P.S.
Optimizely doesn't do anything special on this, instead it's how ASP.NET Core handles multiple authentication methods (see MS docs below)
Authorize with a specific scheme in ASP.NET Core | Microsoft Learn
I hope above helps.
#301048
May 02, 2023 2:50
