Remove trailing slashes in Optimizely 12
Is there a way to remove trailing slashes on front end pages only in Optimizely 12?   This seems to cause an issue with the CMS when I add it to startup.cs
                var options = new RewriteOptions()
                    .AddRedirect("(.*)/$", "$1", 301 /* Moved Permanently */);
                app.UseRewriter(options);
It was causing a websockets issue so I turned it off for now.
#298435
Mar 16, 2023 18:22
Try setting RoutingOptions.UseTrailingSlash to false. Either in Startup.cs or in your appsettings.json file.
This would be the purest solution, as it avoids adding it in the first place.
#298436
Mar 16, 2023 19:42
What was the websockets issues you were facing ?
you have done in a similar manner described here https://world.optimizely.com/blogs/Minesh-Shah/Dates/2023/2/url-rewrites-in-cms12--net-6-/
and I did not face any issues using
options.AddRedirect("(.*)/$", "$1");
#298473
Edited, Mar 17, 2023 0:39
