IContentRepository.Move performance speed up
Hello, im having problems with the performance for a EventListner. I want to speed up the performance, currently it takes around 10 seconds to publish the PageType, in the eventListner I automatically create a map structure. At maximum it creates 3 containers/maps with a hierarchy order and moves the PageType in the bottom of the hierrarchy. After debugging I discover that the IContentRepository.Move slows the method down. Here is my code:
Let me know if you need more information
#311863
Edited, Nov 02, 2023 9:49
The most common way to move forward in this case is to use a profiler like dotTrace to see what is the bottleneck. if it's something we can improve from our side, we'd like to hear about it.
#311864
Nov 02, 2023 9:57
Don't you have an infinite loop here? Shouldn't path != eventPage.ContentLink be path != eventPage.ParentLink? Or even better path.Equals(eventPage.ParentLink, ignoreVersion: true).
#311925
Nov 03, 2023 9:07
Also, why are you casting SaveAction.Publish to the AccessLevel enum?
#311926
Nov 03, 2023 9:09
