How to render long string as html content
Hi Team,
    I have to render the long string as html cotent. Suppose if i will add <b>Hello</b> and <img src="image url" alt="image" width="500" height="600">. It should be display Hello as bold text and image in the page. I have tried XhtmlString property and @Html.Raw() in the view but It is not working.
Any help would be highly appreciated..!
Binay Thakur
#294767
Jan 16, 2023 12:22
I have tried this on Alloy Sample Site and using HTML.Raw worked for me
e.g.
Content Model
Content View
Edit Mode Content Property
Rendered Page
#294777
Edited, Jan 16, 2023 15:25
Hi Minesh Shah (Netcel)
  Thank you for your response.
  It is working for me also. But i wanted to use XhtmlString or TinyMCE controls.
  Do you have any reference for XhtmlString or TinyMCE controls ?
Regards
Binay Thakur
#294828
Jan 17, 2023 11:00
I'm a little confused you have a string property currently on the content type, do you want to change this to an XhtmlString ? Or do you want to  cast the content to an XhtmlString and than use PropertyFor ?
If you want to change
public virtual string TestProperty {get; set;}
to
public virtual XhtmlString TestProperty {get; set;}
My advice would be to create a new XhtmlProperty with a custom getter which gets the Data from the original property if Null and also hide the original property from the editors e.g.
    [UIHint(UIHint.Textarea)]
    [ScaffoldColumn(false)]
    public virtual string TestString { get; set; }
    public virtual XhtmlString TestXhtmlString
        get
            var x = this.GetPropertyValue(p => p.TestXhtmlString);
            if (x == null)
                return new XhtmlString(TestString);
            return x;
        set
            this.SetPropertyValue(p => p.TestXhtmlString, value);
#294829
Edited, Jan 17, 2023 11:21
