This could be caused by case-sensitive URL processing in Linux environment.
Add RouteOptions to Startup.cs:
services.Configure(o => { o.LowercaseUrls = true; });
Any other option why it doesn't exist in the build package (maybe it is the reason of 404 error)? Because locally I have correct structure of ClientResources and the script exists
@Aneta, in our solution we hold these resources within the wwwroot i.e.
Our module.config looks like this
<module clientResourceRelativePath="2.0" loadFromBin="false">
<assemblies>
<!-- The assembly containing the rest store needs to be added. -->
<add assembly="Redacted.Cms" />
</assemblies>
<routes>
<route url="{moduleArea}/{controller}/{action}/">
<defaults>
<add key="moduleArea" value="Redacted.Cms" />
<add key="controller" value="" />
<add key="action" value="Index" />
</defaults>
</route>
</routes>
<dojo>
<paths>
<add name="Redacted" path="~/ClientResources/Scripts" />
</paths>
</dojo>
<clientModule initializer="Redacted/ModuleInitializer">
<moduleDependencies>
<add dependency="Shell" />
<add dependency="CMS" type="RunAfter" />
</moduleDependencies>
</clientModule>
<clientResources>
<!-- Inject our custom Display Option selector -->
<add name="epi-cms.widgets.base" path="~/ClientResources/Scripts/widget/DisplayOptionSelector.js" resourceType="Script"/>
</clientResources>
</module>
And in Project file have the following
<ItemGroup>
<Content Update="module.config">
<CopyToOutputDirectory>Always</CopyToOutputDirectory>
</Content>
</ItemGroup>
Would be worth checking the 3 things over in your solution
I've implemented an editor descriptor and created dojo class: CustomLinkItemModel.js. Locally everything works, but after deployment to Integration, an edit mode is blank for this block and I've noticed this error in the console: GET https://....com/ClientResources/Scripts/CustomLinkItemModel.js 404. I've also noticed that this js file wasn't be added to relaese package before hosting on DXP.
1) The module.config is located in the root directory (projectName.web) and looks like this:
2) Files structure:
3) The editor descriptor includes a following line:
ItemModelType = "projectName/CustomLinkItemModel"
4) The CustomLinkItemModel.js looks like this:
Anybody knows what might be wrong or maybe what is missing?
