You cannot change those values dynamically the way you're describing it. What you can do instead, is to register multiple schemes (with different settings) and then select a scheme with a policy scheme based on the URL. See https://docs.developers.optimizely.com/content-cloud/v12.0.0-content-cloud/docs/mixed-mode-authentication.
We are using two multi-sites and want to use different SSO for both like every site has its own MetaAddress and Wtrealm. We are trying to assign the same in a startup.cs file. How can we identify the site URL(based on site URL we will assign respective meta address and wtrealm) in startup.cs.
Can you please help in this?
