Because of 3.1.0 version it was not working as it's for .net 6 and it was not working. Now installed 3.0.0 which is for .Net 5 and it's working fine.
Thank you.
Hello,
We migrated our project from CMS 11 to 12 using upgrade assistant and resolved build errors related packages that are no longer supported and added packages wherever its being removed by tool and it required for project to run and updated code to support .Net core standard.
Now when we run application we are getting this error:
info: EPiServer.Framework.Initialization.InitializationEngine[0]
Initialization started
fail: EPiServer.Framework.Initialization.InitializationEngine[0]
Initialize action failed for 'Initialize on class EPiServer.Data.DataInitialization, EPiServer.Data, Version=12.8.0.0, Culture=neutral, PublicKeyToken=8fe83dea738b45b7'
System.InvalidOperationException: Unable to resolve service for type 'EPiServer.Marketing.KPI.Dal.KpiDatabaseContext' while attempting to activate 'EPiServer.Marketing.KPI.Dal.BaseRepository'.
at Microsoft.Extensions.DependencyInjection.ServiceLookup.CallSiteFactory.CreateArgumentCallSites(Type serviceType, Type implementationType, CallSiteChain callSiteChain, ParameterInfo[] parameters, Boolean throwIfCallSiteNotFound)
at Microsoft.Extensions.DependencyInjection.ServiceLookup.CallSiteFactory.CreateConstructorCallSite(ResultCache lifetime, Type serviceType, Type implementationType, CallSiteChain callSiteChain)
at Microsoft.Extensions.DependencyInjection.ServiceLookup.CallSiteFactory.TryCreateExact(ServiceDescriptor descriptor, Type serviceType, CallSiteChain callSiteChain, Int32 slot)
at Microsoft.Extensions.DependencyInjection.ServiceLookup.CallSiteFactory.TryCreateExact(Type serviceType, CallSiteChain callSiteChain)
at Microsoft.Extensions.DependencyInjection.ServiceLookup.CallSiteFactory.CreateCallSite(Type serviceType, CallSiteChain callSiteChain)
at Microsoft.Extensions.DependencyInjection.ServiceLookup.CallSiteFactory.<>c__DisplayClass7_0.<GetCallSite>b__0(Type type)
at System.Collections.Concurrent.ConcurrentDictionary`2.GetOrAdd(TKey key, Func`2 valueFactory)
at Microsoft.Extensions.DependencyInjection.ServiceLookup.CallSiteFactory.GetCallSite(Type serviceType, CallSiteChain callSiteChain)
As per this blog https://kunalshetye.com/posts/add-a-b-testing-to-cms12/ added line in startup.cs file
services.AddABTesting(_configuration.GetConnectionString("EPiServerDB"));
But this line is giving error for AddABTesting() method for missing reference.
Can anyone help with this error and how to resolve this?
