ViewComponent-less local block property not working with PropertyFor
Solution is recently upgraded and we are working through the templates...
It has a simple block type with string and Url properties. It has a View file but no ViewComponent class.
It is used in another block added as local block property, and in that block's view it is called using Html.PropertyFor(x => m.CurrentBlock.SimpleBlockTypeProperty)
We then get this error:
InvalidOperationException: The model item passed into the ViewDataDictionary is of type 'SimpleBlock_DynamicProxy', but this ViewDataDictionary instance requires a model item of type 'APageViewModel'.
This error is without any custom property renderer.
Anyone solved this or have some pointers?
#291762
Nov 16, 2022 11:00
Hi Johan,
Are you using there ContentArea?
In my current project we had simillar issue and ve've resolved it by explicit cast to block type.
Example code:
IEnumerable<ContentAreaItem> contentAreaItems = Enumerable.Empty<ContentAreaItem>(); // your content area items
foreach (var block in contentAreaItems.Select(c => c.GetContent() as IContentData))
	switch (block)
		case BlockTypeA blockA:
			@Html.PropertyFor(m => blockA)
			break;
		case BlockTypeB blockB:
			@Html.PropertyFor(m => blockB)
			break;
		case null:
			break;
		default:
			<div>Block not handled.</div>
			break;
#291777
Nov 16, 2022 16:02
Johan Kronberg - Nov 16, 2022 16:05
No, this error seems to only when using PropertyFor on a "local block".
/Johan
We have a temporary fix that seems to work as before but not using PropertyFor but instead calling the View directly using:
@await Html.PartialAsync("SimpleBlock", Model.CurrentBlock.SimpleBlockTypeProperty)
// Or with extra view data...
@await Html.PartialAsync("SimpleBlock", Model.CurrentBlock.SimpleBlockTypeProperty, new ViewDataDictionary(ViewData) { { "cssClass", "some-class" } })
#291779
Nov 16, 2022 16:09
I recently ran into somewhat the same issue - I could not use Html.PropertyFor(x => x.Block) where Block is a actual block instance (rather than a content area or a content link). In my case, I had a dedicated view component for the block, so I just did as below. The error message is very misleading though.
@(await Component.InvokeAsync<SimpleBlockComponent>(new { currentContent = simpleBlock }))
Honestly, I think your solution is fine.
#291782
Edited, Nov 16, 2022 17:04
Sven Tegelmo - Dec 14, 2022 13:17
I was unable to get your work-around to work. It complained that it could not find the view component (I tried adding ViewComponent attribute etc with no luck).
I was able to make it work with this though:
Html.RenderContentData(nextBlock, false);
