Preferred way to access HttpContext in static classes
I'm working my way through an Opti CMS 11 > 12 upgrade. I do not have my entire solution building yet but I have run into a few cases where I need to access the HttpContext in static instances.
First off, I have registered the IHttpContextAccessor in my services collection with the built in AddHttpContextAccessor() extension method.
Because of that, I'm thinking I can inject it like so:
private static Injected<IHttpContextAccessor> _httpContextAccessor;
However, I've read that I could also create a field and then initialize it like so in the constructor:
_httpContextAccessor = new HttpContextAccessor();
Are their any benefits/drawbacks to either approach? Like I said above, I don't have my upgrade running yet so apologies if one option doesn't even work.
#292402
Edited, Nov 29, 2022 22:27
You should be using IHttpContextAccessor, so the former is preferred. The best way is still making your class not static if possible.
#292437
Nov 30, 2022 7:18
Thanks Quan
#292528
Dec 01, 2022 18:06
