Try /episerver/cms instead
Also links should work fine on here, I've never had problem https://world.optimizely.com/documentation/developer-guides/CMS/getting-started/creating-a-starter-project/
Yes that works ... thanks :D
Wonder what configuration in Foundation that makes /episerver alone work.
I wrote an article highlighting this and clarifying more of the setup steps from the Opti documentation. One of the things I do with the solution is set the the path for Debug mode launching the application in the browser. If you check off "Launch Browser" and specify the "Episerver/CMS" path it will launch that each time you run from VS. Saves a bit of confusion and work. If you care for a bit more info about the setup you can read a bit more here.
Will simple not respond to /episerver (404)
Anyone else got this working?
<url-to-world>/documentation/developer-guides/CMS/getting-started/creating-a-starter-project/
Note: apparently I am still not allowed to put urls into posts here
