Hi Matt, haven't experienced it before but it would be helpfull if you can share more details:
1) what Optimizely version you are running?
2) do you mean it doesn't show existing setup of groups assigned to a specific content or you can't add new one to the existing content?
You can do following to try troubleshoot an issue:
1) check application logs for errors
2) check browser console log for FE errors
Best regards,
Milos
Thanks Milos.
It does not appear here...
Nothing in logs or console that would indicate an issue.
Hoping for some assistance/brainwaves...
I have an Optimizely installation that is using standard login for the CMS (not Opti ID, anything custom), and it has many groups of users, which I want to use to define permissions on content items - and yet the groups do not appear in the Access Rights panel.
This is standard functionality that works in every single other CMS implementation I have - anyone have any thoughts as to what setting/config option might be making Opti not display groups for Access Rights please?
