Hello!
We noticed, that personalize stop working in TinyMce. I think it can related with update TinyMce library to 7.* version (Optimizely package 5.*).
Case:
Our source code before publish:
Our source code after publish: removed all html code before publish related with audience.
I tested remove attributes in parent div and it happened when we have
I also tried to remove all pottential related with it things and use default TinyMce configuration, but have the same issue. We also have legacy project on Optimizely TinyMce package (4.*) and it worked.
Also tried to override settings like: extended_valid_elements, valid_children, valid_elements and other and it helps only part of html code, but attribute «class» removed any way.
