Application crashes with SqlNullValueException when loading the CMS UI due to NULL values in the synchronized users table.
hct
hct
The CreateUser method in SynchronizeUsersDB uses SqlDataReader.GetString() without checking for NULL values first.
When the identity provider does not supply all expected claims during authentication, the user record is saved with NULL values, which then causes this exception on subsequent reads.
This appears to be a regression in episerver.cms.core 12.22.10, possibly due to changes in how user data is read from the database.
Current workaround: downgrade to Episerver.CMS.Core 12.22.9
  Error Details
  System.Data.SqlTypes.SqlNullValueException: Data is Null. This method or property cannot be called on Null values.
     at Microsoft.Data.SqlClient.SqlBuffer.get_String()
     at Microsoft.Data.SqlClient.SqlDataReader.GetString(Int32 i)
     at EPiServer.DataAccess.Internal.SynchronizeUsersDB.<FindUsersAsync>g__CreateUser|15_0(DbDataReader reader)
  Steps to Reproduce
  1. User logs in via external identity provider (e.g., Azure AD)
  2. Identity provider syncs user without all required claims (e.g., missing Email, GivenName, or Surname)
  3. User record is created in tblSynchedUser with NULL values in string columns
  4. User navigates to CMS UI
  5. Application attempts to load notifications/subscriptions for the user
  6. FindUsersAsync reads the user record and calls GetString() on a NULL column
  7. Application crashes
#341106
Edited, Nov 26, 2025 15:11
Thanks for the detailed breakdown,  this definitely looks like a regression in 12.22.10, because SynchronizeUsersDB.FindUsersAsync should not be calling GetString() on columns that may contain NULL values.
Users created through external identity providers (Azure AD, Okta, etc.) often arrive with missing claims, and Optimizely normally handles that without errors. The fact that GetString() now throws means NULL checks were removed or changed in the latest release.
The user entry in tblSynchedUser is created by Optimizely’s built-in user synchronization logic, so this is not something you can prevent on your side.
Even if the IdP doesn’t supply email, given_name, or surname, the CMS should still create and read the user safely.
This failure indicates the new version is not handling NULLs correctly.
I would suggest logging this with Optimizely Support, since it’s reproducible and tied to a recent core change.
#341113
Nov 26, 2025 16:06
hct
Possible solution found
  The regression is in EPiServer.DataAccess.Internal.SynchronizeUsersDB at the local function CreateUser inside
  FindUsersAsync(IEnumerable<string> userNames).
  Problem code (12.22.10):
  user.EmailAddress = reader.GetString("Email");           // Throws on NULL
  user.DisplayName = string.Format(...,
      reader.GetString("GivenName"),                       // Throws on NULL
      reader.GetStringSafe(reader.GetOrdinal("Surname")))  // Safe
  Expected (consistent with CreateUserFromReader):
  user.EmailAddress = reader.GetStringSafe(reader.GetOrdinal("Email"));
      reader.GetStringSafe(reader.GetOrdinal("GivenName")),
  The GetStringSafe extension method is already used for Surname but was not applied to Email and GivenName.
#341114
Edited, Nov 26, 2025 19:50
hct
Response from Optimizely support: Our dev team has worked on our work item CMS-47341 to fix the issue. Code has been merged.
#341117
Edited, Nov 27, 2025 8:20
Sunil KumAR - Nov 27, 2025 9:56
Great!
I am from the support team.
If anyone can tolerate the null exception by filling patch (duplicated) data, there is the ClaimTypeOptions that can be configured to map with Email, GivenName, Surname with available field from your IDP.
For example, I used Entra ID. I can use this code to force all needed fields to get data from preferred_username.
services.Configure<ClaimTypeOptions>(x =>
x.Email = "preferred_username";
x.GivenName = "preferred_username";
x.Surname = "preferred_username";
Users have to clear site data so CMS doesn't recognise logged in, then log in to resync.
#341129
Nov 28, 2025 3:04
Hi, when will CMS.Core 12.23.0 be released?
#341305
Dec 18, 2025 9:28
