Forms Description message referencing to field with wrong name
Display Message refering to a field using wrong name, which could cause confusion.
Forms 5.7.2
How would I send in a Bug Report?
#340819
Oct 22, 2025 13:17
You can report an Optimizely bug by submitting a support ticket through support@optimizely.com
At least that is the way we have used, if its a bug they wil create a bug task, or if it relates to an already registered bug you will get the info.
#340853
Oct 23, 2025 9:38
You’re right, that message looks confusing – it’s coming from the built-in Forms localization rather than anything you’ve configured in your form, so you can’t change it per-form from the UI.
In Forms 5.7.2 this is effectively a text/UX bug in the default language resources. Until Optimizely changes it in a future release, 1 below option you can try:
Override the text via Forms localization:
You can override any of the default Forms strings by copying and editing the embedded language XML and then placing it under your site’s Resources/LanguageFiles folder:
  • Extract EPiServer.Forms_EN.xml from
    \modules\_protected\EPiServer.Forms\EPiServer.Forms.zip\EmbeddedLangFiles\
  • Locate the entry for the description/help text that’s using the wrong field name.
  • Adjust the value to the wording you want (for example, remove or correct the misleading field reference).
  • Drop the modified XML into \Resources\LanguageFiles so it overrides the embedded resource.
After an app restart, the Forms UI will use your corrected text instead of the default one.
#341096
Nov 26, 2025 8:40
