CMS View and preview mode not showing changes
When we are updating any page/block data, first time clicking on View mode/preview shows the updated changes. But on further updating the page/block, both the View and preview mode keeps showing the previous data and does not show the updated changes. We have tried clearing cache and refreshing the page as well.
We are using the quick edit dialog to update the block, and save it.
We are on episerver cms 12.31.2.
Is there any caching in CMS that can be checked?
#335948
Edited, Jan 22, 2025 7:58
Hi, some additional questions
  • Is this a regular MVC-webb?
  • Do the changes appear when you publish them?
  • Are you using a CDN?
  • Is this in your development environment or in a test/production environment?
    • If this is on test/prod, are you using DXP or is it OnPrem
#336147
Jan 28, 2025 9:29
Hi Eric,
Yes this is a regular MVC application hosted on DXP. The changes appear when they are published. This issue is occuring on all 3 environments - integration, preprod and production. We are using cloudflare CDN
#336166
Jan 28, 2025 13:30
Have you added AddCmsCloudPlatformSupport to your startup? (Enabling Cloud Support for CMS 12 - a look under the hood)
And can you reproduce this in a local development environment?
#336168
Jan 28, 2025 13:56
Yes, we have added AddCmsCloudPlatformSupport to  startup file. We are not able to reproduce this issue locally.
#336169
Jan 28, 2025 14:04
What status code and cache control result will you get on the loaded document?
E.g
#336202
Jan 29, 2025 21:10
The status is 200 OK, and below is the cache control. This means it is getting cached at cloudlfare. Because once we clear CDN cache, and then click preview, then we can see the changes, then the doc gets cached again, and stops reflecting new changes.
#336227
Jan 30, 2025 7:31
Cool, then we know why.
It's recommended having CDN disabled in edit mode.
You can also (probably) bypass the CDN by using the webistes azurewebsites.net address.
Another approach is to have a separate domain, e.g. edit.yourdomain.com, and ensuring that CF won't cache that.
#336228
Jan 30, 2025 9:51
We finally ended up creating a middleware where we are setting no cache for preview and view mode.
#336790
Feb 15, 2025 3:14
