Hi Dave,
is it working fine in local environment, just on Azure throws that error?
Do you see Optimizely alert message after logged in to edit mode that Real-time updates are disabled?
Have you checked WebSocket is enabled on Azure service?
Hi Dave,
I think it's related to logged-in CMS users closing the browser
This looks like it was fixed in EPiServer.CMS.UI 12.29.0. - https://world.optimizely.com/documentation/Release-Notes/ReleaseNote/?releaseNoteId=CMS-32095
Hi Dave,
You are using DotNet 8, can you change that to .net 6 and check if that works.
reference link
Optimizely has been supporting .NET 8 since it came out in November 2023. See https://world.optimizely.com/blogs/Magnus-Rahl/Dates/2023/11/support-for--net-8/
This issue is not related to the framework. It's got to do with websockets that is used for parts of the new UI. When switching between CMS/Commerce UI and any third-part UI/plugin, this error is thrown. On our end we can reproduce it locally as well. As already mentioned, it seems to be fixed in 12.29.0, but I haven't had a chance to test it yet myself.
