EPiServer.Find.ServiceException: 401 Unauthorized - Just in localhost
Hello all,
Yesterday, out of the blue, I started receiving errors when code that uses Find is called, but only in localhost:
EPiServer.Find.ServiceException: 'Response status code does not indicate success: 401 (Unauthorized). Unauthorized'
The same/similar error is reported in abundance when running the Search & Nav Indexing.
I have rolled back both code and database to try and solve this, but nothing.  I realize it's probably something with my local machine, but I don't know what changes would cause this behavior.
Any ideas/help is appreciated!
Thanks, Kevin
#319879
Apr 02, 2024 19:38
Hi Kevin
What Search & Nav instance / license do you use? If your local solution is currently using developer demo license, it might be your license was expired. You can obtain a new one from Optimizely Find (episerver.com)
p.s. Developer demo license expired every 30 days
#319919
Apr 03, 2024 0:19
Thanks for the response Vincent.
I have used developer licenses in the past, but the one we have has been in use for maybe 11 months.  I'll contact support instead.
As a test, I did register a new developer demo license, and things are working now, so I think it is the correct answer.
#319927
Apr 03, 2024 14:10
Hi Kevin
Glad to hear above helps for your troubleshooting. If you're using developer license, it should not be expired in theory. Good call to raise support ticket.
#319982
Apr 03, 2024 23:18
