Inline blocks disabled - CMS still creates them
I have updated CMS to version 12.22.5 - I don't want to use Inline block
Tried to use (both in appsettings and Startup.cs):
"InlineBlocksInContentAreaEnabled": false
But still when I try to create a new block from Content Area -> Create a new block => Inline block is created.
#308323
Sep 11, 2023 7:30
Have you reported this directly to optimizely?
I have just upgraded a project and haven't tested the feature yet. The project i am work on is completely new. Is yours the same?
Interested to know if it is more an upgrade to 12.20.0 to 12.22 5 or somewhere in between as it might be a problem. If you have already upgraded to a version which introduced inline blocks and are now going back to disabling them as it may have already converted the blocks to I line blocks.
As I understood from opti you can only use the disable setting if you have not already upgraded to inline blocks.
Not much help I know, however seems like we should have a way to go back.
Paul
#308329
Sep 11, 2023 10:32
I had a version 12.17.X and updated to 12.22.5
I was informed that you need to opt-in to use inline blocks. Adding appsettings was only for making it explicit that I don't want to have that feature.
It was not reported directly yet.
Dawid
#308331
Sep 11, 2023 10:37
