Delete EPiServer.Commerce.Shell folder under modules/protected then try reinstalling.
Also check references. In your web project goto dependencies/packages. Make sure they all look loaded.
Just to add if you have a multi-project setup, ensure that you have consolidated the nuget packages.
I do remember on a recent upgrade while the main project was referencing the correct version a warning appearing informing me it was using a different version.
Might be worth checking the version of the dll's in the bin folder also.
Paul
I am setting up .Net6 Optimizely solution, reusing existing code from .net47.
I can see login/register page, but after login I got such error as below.
- I had EPiServer.Commerce v14.11.0 nuget referenced,
- I put all EPi nugets references in single core project
- EPiServer.Commerce.Shell.dll gets added to modules/_protected directory with correct version
- EPiServer.Commerce.Shell.dll is present in bin/Debug/net6.0 folder with correct version
- cleaned bin/obj folders in all solution projects before build
I go through bunch of topics on and off this forum and can't fix it :/
Here are some troubleshooting steps that you can check.
* Check that the correct version of 'EPiServer.Commerce.Shell.dll' is referenced and located in the appropriate folder.
* Ensure all necessary assembly references are correctly added to the project.
* Clean the solution, rebuild it, and make sure the DLL is included in the build output.
* Verify file permissions for the DLL and ensure the application has access to it.
* Double-check the file location and consider re-adding the reference or copying the DLL to the correct location.
* Review any custom assembly loading logic or potential conflicts with other assemblies.
If these steps don't resolve the issue, consult the documentation or seek support from EPiServer for assistance.
