What seems to work is install SQL Server, not use Local DB or SQL Server Express. The Developer Edition is good enough for local use. The import succeeded.
I'm facing an issue when importing a database to my LocalDB instance. The .bacpac file is an export of my production database and is 1GB in size.
The error:
I think the problem is that the log file is limited to 2GB and has autogrowth disabled. When re-enabling indexes, the log file size needs to be able to grow beyond that limit but it fails.
I've tried to following:
Anyone had success with restoring a large database locally?
