That's true, the EmptyDefinition property is never set
private static SiteDefinition EmptyDefinition;
public static SiteDefinition Empty
get
return EmptyDefinition ?? new SiteDefinition
StartPage = ContentReference.EmptyReference
internal set
EmptyDefinition = value;
This property will always be recreated.
Create a custom class if you must have a singleton :P
public class SiteDefinitionCustom : IReadOnly<SiteDefinitionCustom>, IReadOnly
public bool IsReadOnly { get; private set; }
get
// horrible but will work 😁
if(EmptyDefinition is null)
EmptyDefinition = new SiteDefinition
return EmptyDefinition;
internal set
public object CreateWritableClone()
throw new NotImplementedException();
public void MakeReadOnly()
SiteDefinitionCustom IReadOnly<SiteDefinitionCustom>.CreateWritableClone()
The description of SiteDefinition.Empty says: This is a singleton instance which can be compared against using object comparison. However, if SiteDefinition.Empty is compared to itself, the result returned is false meaning this instance is not a singleton (SiteDefinition.Empty == SiteDefinition.Empty => false).
For comparison, on the .net-framework, SiteDefinition.Empty used to be initialized in WebIdentityInitialization initialization module.
