SetDefaultValues for IList of blocks creates default blocks
Version: 12.25.1
Block is a simple link block with a heading, text and PageReference for target.
We have content that has an IList property of this link block and we would like the property to be created with a couple of links setup by default. We use SetDefaultValues to create a list with a few link blocks setup (using some example values here):
    AccordionItems = new List<SimpleLinkBlock>
        new SimpleLinkBlock
            ButtonText = "Simple Link Button 1",
            Heading = "Heading Test 1",
            Target = ContentReference.StartPage
        new SimpleLinkBlock
            ButtonText = "Simple Link Button 2",
            Heading = "Heading Test 2",
The result when creating a new instance of the Content is a list of 2 SimpleLinkBlock's that are completely empty. The values we set does not get copied.
Is there a workaround that does not involve moving SimpleLinkBlock away from being a block and creating descriptors?
#312941
Nov 22, 2023 11:41
Hi Glenn Adrian,
You should create instance like this instead:
var blockPropertyFactory = ServiceLocator.Current.GetInstance<IBlockPropertyFactory>();
var block1 = blockPropertyFactory.Create<SimpleLinkBlock>();
block1.ButtonText = "Simple Link Button 1";
block1.Heading = "Heading Test 1";
block1.Target = ContentReference.StartPage;
var block2 = blockPropertyFactory.Create<SimpleLinkBlock>();
block2.ButtonText = "Simple Link Button 2";
block2.Heading = "Heading Test 2";
TestBlocks = new List<SimpleLinkBlock> { block1, block2 };
Reference: List Properties (optimizely.com)
#313705
Dec 05, 2023 12:51
Glenn Adrian - Dec 06, 2023 16:32
Thank you, I did find an alternative method of setting the property in the Property dictionary directly which worked but this is cleaner.
This however only works for the first layer of Lists. I have another situation where I have a list of a block which contains another list. I can set the default values of the first list but the next layer ignores anything I try to do.
