We have done something Similar and had to use Search and Navigation to Find the Page to serve full example here
public class CampaignRouter : IPartialRouter<InsightLandingPage, CampaignPage>
#if DEBUG
private readonly TimeSpan _cacheTimespan = new TimeSpan(0, 0, 0);
#else
private readonly TimeSpan _cacheTimespan = new TimeSpan(0, 30, 0);
#endif
private ContentReference _container;
private string _urlSegment;
public CampaignRouter()
var settings = ServiceLocator.Current.GetInstance<ISiteSettingsProvider>();
_container = settings.Current.InsightsContainer;
public object RoutePartial(InsightLandingPage content, SegmentContext segmentContext)
if (!content.ContentLink.CompareToIgnoreWorkID(_container))
return null;
var nextSegment = segmentContext.GetNextValue(segmentContext.RemainingPath);
var urlSegment = nextSegment.Next;
if (string.IsNullOrEmpty(urlSegment))
return null;
ArticleBasePage article = null;
var cacheKey = $"routing-insights-{urlSegment}";
var cache = ServiceLocator.Current.GetInstance<ICache<ArticleBasePage>>();
_urlSegment = urlSegment;
if (cache.IsExists(cacheKey))
article = cache.Get(cacheKey, GetArticleBasePage);
else
article = GetArticleBasePage();
if (article != null) cache.AddToCache(cacheKey, article, _cacheTimespan);
segmentContext.RemainingPath = nextSegment.Remaining;
segmentContext.RoutedContentLink = article.ContentLink;
return article;
private ArticleBasePage GetArticleBasePage()
var urlSegment = _urlSegment;
var searchContext = SearchClient.Instance
.Search<ArticleBasePage>(SearchClient.Instance.Settings.Languages.GetSupportedLanguage("en"))
.Filter(x => x.URLSegment.MatchCaseInsensitive(urlSegment))
.Filter(d => d.Ancestors().Match(_container.ID.ToString()))
.StaticallyCacheFor(this._cacheTimespan)
.Select(r => r.ContentLink);
var searchResults = searchContext.GetResult().FirstOrDefault();
if (!ContentReference.IsNullOrEmpty(searchResults))
var contentRepository = ServiceLocator.Current.GetInstance<IContentRepository>();
article = contentRepository.Get<ArticleBasePage>(searchResults);
return article;
public PartialRouteData GetPartialVirtualPath(
CampaignPage content,
string language,
RouteValueDictionary routeValues,
RequestContext requestContext)
var contentLink = requestContext.GetRouteValue("node", routeValues)
as ContentReference;
if (!content.ContentLink.CompareToIgnoreWorkID(contentLink))
return null;
if (PageEditing.PageIsInEditMode)
return null;
return new PartialRouteData
BasePathRoot = _container,
PartialVirtualPath = content.URLSegment
Hi team,
I'm working on partial route in purpose to remove a segment from an URL.
We have the following structure:
Landing Page → Container Page → Start Page → Standard Page → [other pages of type Standard Page]
I need for each page under the ContainerPage to hide its segment from URL.
Example: http://siteHost/landingPage/containerPage/startPage/standardPage1/standardPage2/
Expected to be: http://siteHost/landingPage/startPage/standardPage1/standardPage2/
(no containerPage segment)
There is a partial router, it inherits from
where BasePage is a base type for both page types - StartPage and StandardPage. Methods of that interface are implemented:
Router is registered. We get into partial router for pages like following:
But for the page from example it is not working - we even don't get into the method.
Did I miss something in the solution?
Thanks in advance!
