stores/contentversion 500 error when trying to publish
Jay
Jay
We have started getting an error in the cms when publishing.  The autosave is taking a very long to complete and getting a misleading error notification, to complicate things more the error log doesn't show a stack trace so I believe the error we are seeing is masking the actual error.
It occurs when dojo.js makes a call to the stores/contentversion, the response is a 500 error.
Any ideas much appreciated.
#284204
Jul 22, 2022 8:45
Is this development or production?
If you open your browser console, you can probably see more details of the error. what is it
#284273
Jul 23, 2022 9:06
Jay
It's in both development and production. All I can see in the console is the JS call to episerver/cms/stores/notifications end point fails first with a 500 error and then it just keeps polling episerver/cms/stores/contentversion which again returns a 500 error.
There have been no code/configuration changes and this only started happening on 18th July from what we can see in the logs.
Pretty sure the error that we are gettingis a bit of a red herring and it is masking the actiual error. We get that same error showing up in the logs but no other information!
I've been trying to work out what code runs at those end points and where that os making calls to, I'm guessing that is what is failing.
#284308
Jul 24, 2022 19:37
Jay
Stack trace from error log
System.AggregateException: One or more errors occurred. ---> System.Net.Http.HttpRequestException: An error occurred while sending the request. ---> System.Net.WebException: Unable to connect to the remote server ---> System.Net.Sockets.SocketException: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond 137.117.132.111:443
   at System.Net.Sockets.Socket.InternalEndConnect(IAsyncResult asyncResult)
   at System.Net.Sockets.Socket.EndConnect(IAsyncResult asyncResult)
   at System.Net.ServicePoint.ConnectSocketInternal(Boolean connectFailure, Socket s4, Socket s6, Socket& socket, IPAddress& address, ConnectSocketState state, IAsyncResult asyncResult, Exception& exception)
   at System.Net.HttpWebRequest.EndGetRequestStream(IAsyncResult asyncResult, TransportContext& context)
   at System.Net.Http.HttpClientHandler.GetRequestStreamCallback(IAsyncResult ar)
   at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)
   at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
   at System.Net.Http.HttpClient.<FinishSendAsyncBuffered>d__58.MoveNext()
   at System.Threading.Tasks.Task.ThrowIfExceptional(Boolean includeTaskCanceledExceptions)
   at System.Threading.Tasks.Task`1.GetResultCore(Boolean waitCompletionNotification)
   at System.Threading.Tasks.Task`1.get_Result()
   at SiteAttentionModule.Data.SiteAttentionApi.PagedPublish(PagePublishedRequest request)
   at SiteAttentionModule.PublishEventInitializationModule.ContentEvents_SavedContent(Object sender, ContentEventArgs e)
   at System.EventHandler`1.Invoke(Object sender, TEventArgs e)
   at EPiServer.Core.Internal.DefaultContentEvents.RaiseContentEvent(String key, ContentEventArgs eventArgs)
   at EPiServer.Core.Internal.DefaultContentRepository.RaisePostSaveEvents(SaveContentEventArgs eventArgs, StatusTransition transition, Boolean isNew, Boolean isNewLanguageBranch)
   at EPiServer.Core.Internal.DefaultContentRepository.Save(IContent content, SaveAction action, AccessLevel access)
   at EPiServer.Cms.Shell.Service.Internal.ContentService.Save(IContent content, SaveAction saveAction, AccessLevel accessLevel)
   at EPiServer.Cms.Shell.Service.Internal.ContentService.CreateDraft(ContentReference contentLink, Boolean setAsCommonDraft)
   at EPiServer.Cms.Shell.UI.Rest.Internal.ContentVersionStore.Post(CreateContentVersionViewModel entity)
   at lambda_method(Closure , ControllerBase , Object[] )
   at System.Web.Mvc.ActionMethodDispatcher.Execute(ControllerBase controller, Object[] parameters)
   at System.Web.Mvc.ReflectedActionDescriptor.Execute(ControllerContext controllerContext, IDictionary`2 parameters)
   at System.Web.Mvc.ControllerActionInvoker.InvokeActionMethod(ControllerContext controllerContext, ActionDescriptor actionDescriptor, IDictionary`2 parameters)
   at System.Web.Mvc.Async.AsyncControllerActionInvoker.<>c.<BeginInvokeSynchronousActionMethod>b__9_0(IAsyncResult asyncResult, ActionInvocation innerInvokeState)
   at System.Web.Mvc.Async.AsyncResultWrapper.WrappedAsyncResult`2.CallEndDelegate(IAsyncResult asyncResult)
   at System.Web.Mvc.Async.AsyncResultWrapper.WrappedAsyncResultBase`1.End()
   at System.Web.Mvc.Async.AsyncControllerActionInvoker.EndInvokeActionMethod(IAsyncResult asyncResult)
   at System.Web.Mvc.Async.AsyncControllerActionInvoker.AsyncInvocationWithFilters.<>c__DisplayClass11_0.<InvokeActionMethodFilterAsynchronouslyRecursive>b__0()
   at System.Web.Mvc.Async.AsyncControllerActionInvoker.AsyncInvocationWithFilters.<>c__DisplayClass11_2.<InvokeActionMethodFilterAsynchronouslyRecursive>b__2()
   at System.Web.Mvc.Async.AsyncControllerActionInvoker.<>c__DisplayClass7_0.<BeginInvokeActionMethodWithFilters>b__1(IAsyncResult asyncResult)
   at System.Web.Mvc.Async.AsyncResultWrapper.WrappedAsyncResult`1.CallEndDelegate(IAsyncResult asyncResult)
   at System.Web.Mvc.Async.AsyncControllerActionInvoker.EndInvokeActionMethodWithFilters(IAsyncResult asyncResult)
   at System.Web.Mvc.Async.AsyncControllerActionInvoker.<>c__DisplayClass3_6.<BeginInvokeAction>b__4()
   at System.Web.Mvc.Async.AsyncControllerActionInvoker.<>c__DisplayClass3_1.<BeginInvokeAction>b__1(IAsyncResult asyncResult)
   at System.Web.Mvc.Async.AsyncControllerActionInvoker.EndInvokeAction(IAsyncResult asyncResult)
   at EPiServer.Shell.Services.Rest.RestControllerBase.EndExecute(IAsyncResult asyncResult)
   at EPiServer.Shell.Services.Rest.RestHttpHandler.EndProcessRequest(IAsyncResult result)
   at System.Web.HttpApplication.<>c__DisplayClass285_0.<ExecuteStepImpl>b__0()
   at System.Web.HttpApplication.StepInvoker.Invoke(Action executionStep)
   at System.Web.HttpApplication.StepInvoker.<>c__DisplayClass4_0.<Invoke>b__0()
   at Microsoft.AspNet.TelemetryCorrelation.TelemetryCorrelationHttpModule.OnExecuteRequestStep(HttpContextBase context, Action step)
   at System.Web.HttpApplication.<>c__DisplayClass284_0.<OnExecuteRequestStep>b__0(Action nextStepAction)
   at System.Web.HttpApplication.ExecuteStepImpl(IExecutionStep step)
#284309
Jul 24, 2022 20:45
it seems your site is trying to call a 3rd service everytime it publishes. time to check your SiteAttention settings.
#284349
Jul 25, 2022 6:03
Jay
It seems the SiteAttention module is calling an endpoint that is no longer available! Uninstalling the SiteAttention package fixed the problem.
#284436
Jul 26, 2022 10:44
