VisitorGroupMembershipModel has changed mappings following upgrade from CMS 11 to 12
VisitorGroupMembershipModel has changed mappings following upgrade from CMS 11 to 12, which breaks already existing visitor groups that uses VisitorGroupMembershipModel.
In CMS 11 it seems VisitorGroupMembershipModel has non-nullable Guid VisitorGroupId, but that changed to a nullable Guid in CMS 12. There is no EPiServerDataStoreAttribute.AutomaticallyRemapStore on VisitorGroupMembershipModel, so in the end I get the following error:
typeBag entry with name 'VisitorGroupId' has a CLR type of System.Nullable`1[[System.Guid, System.Private.CoreLib, Version=6.0.0.0, Culture=neutral, PublicKeyToken=7cec85d7bea7798e]] but the mapping with the same name has a CLR type of System.Guid.
Is it a short term solution to run this query?
UPDATE tblBigTableStoreInfo
SET PropertyType = 'System.Nullable`1[[System.Guid, System.Private.CoreLib, Version=6.0.0.0, Culture=neutral, PublicKeyToken=7cec85d7bea7798e]]'
WHERE fkStoreId = X AND PropertyName = 'VisitorGroupId'
Also, following this upgrade from CMS 11 to 12 with many issues I feel you should really start with bug bounties...
#293443
Dec 20, 2022 11:40
Also had to run the following script:
UPDATE tblSystemBigTable
SET String03 = 'EPiServer.Personalization.VisitorGroups.Criteria.VisitorGroupMembershipCriterion, EPiServer.Cms.AspNetCore'
WHERE String03 = 'EPiServer.Personalization.VisitorGroups.Criteria.VisitorGroupMembershipCriterion, EPiServer.Cms.AspNet'
Any input from Optimizely here? Seems like a bug for me.
#295361
Jan 26, 2023 7:35
This should happen automatically on startup with automatic schema updates.  Not sure why it was not run for you but we defintely hav a script to update.
#295381
Jan 26, 2023 17:02
