ASP NET Identity migration not working if previously used with Commerce DB
I'm upgrading from Commerce 13.32.5 to 14.5.0, and one step is to upgrade ASP NET Identity. There's a built in migration for this, located in EPiServer.Cms.UI.AspNetIdentity.Schema.AspNetIdentitySchemaUpdater<TUser>. However, this script does not work if you're targeting the Commerce DB, due to it also including transactions to tblBigTable, amongst others.
I don't have to store users in the Commerce DB, but now that it is the current case - I want to continue doing so. Also, if this is not supported - you should update Foundation to account for this, as that project also uses the Commerce DB for ASP NET Identity users.
#288765
Oct 06, 2022 14:55
I believe we are looking into this, bug CMS-24819
#288993
Oct 11, 2022 7:49
- Oct 11, 2022 12:21
Thanks!
This was fixed in EPiServer.CMS.UI 12.13.2
#295360
Jan 26, 2023 0:18
