Bug when setting Organization in abstract OrderGroup class
Found a bug in Mediachase.Commerce 13.28.0
Guid? IOrderGroup.Organization
        get
            if (string.IsNullOrEmpty(OwnerOrg))
                return null;
            if (Guid.TryParse(OwnerOrg, out var result))
                return result;
            return null;
        set
            if (value.HasValue)
                OwnerOrg = value.ToString();
            OwnerOrg = null;
The setter is always setting OwnerOrg to null.
Workaround:
Use OwnerOrg field (string) instead.
#248341
Feb 08, 2021 13:50
It took me a second try to see where the bug is. I'll file a bug for the COmmerce team. Thanks for bringing this into our attention
#248345
Feb 08, 2021 15:35
