Exporting content doesn't work in a multi-node setup
Hello
We're migrating our CMS (11.20) to Azure. Exporting content from the admin site does not seem to work.
It seems the export is generated in the user's temp folder (e.g. c:\windows\temp\). We tried to change this path to a fileshare which is common to all CMS nodes. The export is generated but can't be downloaded in the UI.
Are we missing something? Is this a supported scenario? Or does this only work with sticky sessions?
How can we fix this while keeping the multi-node setup?
Regards
Marc
EPiServer.CMS: 11.20.0
EPiServer.CMS.UI: 11.30.0
#230752
Edited, Nov 12, 2020 12:44
Hi Marc
It sounds like you don't have Sticky Sessions enabled and the load balancer lead you to a different server than the one that generated the export file.
You can either:
  1. Set up a dedicated single-instance edit site on a separate App Service, or
  2. Enable Sticky Sessions on the multi-instance App Service
I personally prefer the first option.
#231142
Nov 19, 2020 17:51
Hi Stefan
I found an open feature request that would make it possible to support this without sticky sessions: Possible to export data in load balanced environment with non-sti (episerver.com)
Supporting sticky sessions is not straightforward in our environment. We use a Application Gateway / Service Fabric setup.
We'll implement the first option, deploying a single-instance edit site. Downside is this extra instance will also count in for our cloud license.
#231174
Nov 20, 2020 9:45
