Content Delivery Api Search returns only Commerce Items
In our Find Index we have regular content items and commerce items. Maybe I am mistaken, but 'api/episerver/v2.0/search/content/' should return all content items available in the index, right? But only the commerce items are returned. This is also the case in the UI, when I go to Configure and type something to preview the boosting effect I only get commerce items.
#230490
Nov 06, 2020 11:52
I will ask QA team to look into this. Thanks for bringing this into our attention
#230584
Nov 09, 2020 10:44
   By default this endpoint 'api/episerver/v2.0/search/content/' return max 100 records, not all. Commerce catalog has more than 100 records, that why you can see only Commerce content.
  You can use endpoint {{url}}/api/episerver/v2.0/search/content?query=Start >> the Start page will be return. Or remove almost Commerce content, you will see the CMS content when run endpoint.
#230634
Edited, Nov 10, 2020 9:07
If I filter on a specific contenttype though, like a blog page, they aren't returned. And as I said, in the Find UI only commerce content is returned. And we have on the dev environment only 29 products, so the other items should be there methinks
#230637
Edited, Nov 10, 2020 9:48
