We noticed an issue with the Insert/Edit image in TINYMCE
If you select and existing image, click on the button, everything works fine.
However, if you click on the button, insert a new image and click on OK, it inserts the image, but the Insert/Edit image screen is not closing. If you hit ok again, it inserts another image. If you hit cancle or the x in the corner, it closes. Only the OK button seems to be be the issue when inserting a new image.
Also, we are exerencing a slowdown when opening pages through the page tree. It's been taking forever to go between pages and it seems to occasionally get stuck on a "dojo.preventcache" call. This is causing the "Preview Unavailable Failed to load the preview within the given time constraints." to display frequently.
Anybody else seeing this?
