EPiServer.CMS.UI 11.14.0 Cannot Read Property "ContentData" of Null error
I got this same error after updating to EPiServer.CMS.UI 11.14.0.  It is preventing the publish menu from dropping down correctly
https://world.episerver.com/forum/developer-forum/-Episerver-75-CMS/Thread-Container/2019/1/cannot-read-property-contentdata-of-null----publish/
When  I downgraded to EPiServer.CMS.UI  11.13.2, the drowndown menu worked fine.
#200263
Jan 07, 2019 21:00
Hi I got the same issue with package 11.16...
#201000
Feb 01, 2019 11:39
Also seeing this on 11.16.  Am going to try upgrading Epi and see if that helps.
Did you ever find a resolution?
#228335
Sep 23, 2020 17:28
Hi Dylan
Do you have Episerver.Marketing.Testing package installed in your solution? if yes, which version is currently installed?
There is a known bug on version 2.5.4
https://world.episerver.com/documentation/Release-Notes/ReleaseNote/?releaseNoteId=MAR-1213
#228359
Sep 24, 2020 0:11
