Can you try with
System.Drawing.Image.FromStream(stream, false, false);
this ignore the format of the stream
Setting validateImageData boolean FALSE has the same effect: large PNG files throw an error, whereas small PNG files and JPG files work fine.
Thanks Valdis Iljuconoks; what would I have to convert into what in that case?
if I skip my laziness and think once more, there could be 2 options to solve this:
1) using image converter:
using (var stream = img.BinaryData.OpenRead())
var ic = new System.Drawing.ImageConverter();
var img = (System.Drawing.Image)ic.ConvertFrom(stream.ReadAllBytes());
2) or try to load up binary data into memory stream first:
using(var memStream = new MemoryStream())
stream.CopyTo(memStream);
memStream.Position = 0;
var image = System.Drawing.Image.FromStream(memStream, false);
image.Dispose();
however, just to note that I was able to load up 1Mb png image using your code fragment above..
When I try to use a Stream created using [media].BinaryData.OpenRead(), I get the following exception trying to load that stream into an Image object:
Parameter is not valid.
at System.Drawing.Image.FromStream(Stream stream, Boolean useEmbeddedColorManagement, Boolean validateImageData)
at System.Drawing.Image.FromStream(Stream stream)
at ###.Controllers.HomePageController.LoadImages() in ###\HomePageController.cs:line 48
This only occurs for PNG files that are bigger than usual (in this case a file of 4.815 Kb), JPG files work fine.
Here is the (simplified) sample code:
var content = ServiceLocator.Current.GetInstance().Get(imageContentReference);If I try to load the exact same image using native .NET code it also works fine:
