System.ArgumentException: Item has already been added. Key in dictionary: '.EPiForm_VisitorIdentifier'
Been getting alot of this error for quite some time now. Anyone have a clue what might be causing this?
The site is load balanced between two servers with a Netscaler in front. SessionState is stored in SQLServer
It seems the error first occured with following packages:
Current packages:
Stacktrace:
System.Web.HttpException (0x80004005): Error executing child request for handler 'System.Web.Mvc.HttpHandlerUtil+ServerExecuteHttpHandlerAsyncWrapper'. ---> System.ArgumentException: Item has already been added. Key in dictionary: '.EPiForm_VisitorIdentifier' Key being added: '.EPiForm_VisitorIdentifier'
at System.Collections.Hashtable.Insert(Object key, Object nvalue, Boolean add)
at System.Collections.Specialized.NameObjectCollectionBase.BaseAdd(String name, Object value)
at System.Web.HttpRequest.FillInCookiesCollection(HttpCookieCollection cookieCollection, Boolean includeResponse)
at System.Web.HttpRequest.ResetCookies()
at System.Web.HttpResponse.SetCookie(HttpCookie cookie)
at EPiServer.Forms.Core.Internal.VisitorIdentify.DefaultVisitorIdentifyProvider.SetVisitorIdentifier(String visitorIdentifier)
at EPiServer.Forms.Controllers.FormContainerBlockController.SetVisitorIdentifierIfNeeded(HttpContextBase httpContext)
at EPiServer.Forms.Controllers.FormContainerBlockController.Index(FormContainerBlock currentBlock)
at lambda_method(Closure , ControllerBase , Object[] )
at System.Web.Mvc.ReflectedActionDescriptor.Execute(ControllerContext controllerContext, IDictionary`2 parameters)
at System.Web.Mvc.ControllerActionInvoker.InvokeActionMethod(ControllerContext controllerContext, ActionDescriptor actionDescriptor, IDictionary`2 parameters)
at System.Web.Mvc.Async.AsyncControllerActionInvoker.b__39(IAsyncResult asyncResult, ActionInvocation innerInvokeState)
at System.Web.Mvc.Async.AsyncResultWrapper.WrappedAsyncResult`2.CallEndDelegate(IAsyncResult asyncResult)
at System.Web.Mvc.Async.AsyncControllerActionInvoker.EndInvokeActionMethod(IAsyncResult asyncResult)
at System.Web.Mvc.Async.AsyncControllerActionInvoker.AsyncInvocationWithFilters.b__3d()
at System.Web.Mvc.Async.AsyncControllerActionInvoker.AsyncInvocationWithFilters.<>c__DisplayClass46.b__3f()
at System.Web.Mvc.Async.AsyncControllerActionInvoker.EndInvokeActionMethodWithFilters(IAsyncResult asyncResult)
at System.Web.Mvc.Async.AsyncControllerActionInvoker.<>c__DisplayClass21.<>c__DisplayClass2b.b__1c()
at System.Web.Mvc.Async.AsyncControllerActionInvoker.<>c__DisplayClass21.b__1e(IAsyncResult asyncResult)
at System.Web.Mvc.Async.AsyncControllerActionInvoker.EndInvokeAction(IAsyncResult asyncResult)
at System.Web.Mvc.Controller.b__1d(IAsyncResult asyncResult, ExecuteCoreState innerState)
at System.Web.Mvc.Async.AsyncResultWrapper.WrappedAsyncVoid`1.CallEndDelegate(IAsyncResult asyncResult)
at System.Web.Mvc.Controller.EndExecuteCore(IAsyncResult asyncResult)
at System.Web.Mvc.Controller.EndExecute(IAsyncResult asyncResult)
at System.Web.Mvc.MvcHandler.b__5(IAsyncResult asyncResult, ProcessRequestState innerState)
at System.Web.Mvc.MvcHandler.EndProcessRequest(IAsyncResult asyncResult)
at System.Web.Mvc.HttpHandlerUtil.ServerExecuteHttpHandlerWrapper.<>c__DisplayClass4.b__3()
at System.Web.Mvc.HttpHandlerUtil.ServerExecuteHttpHandlerWrapper.Wrap[TResult](Func`1 func)
at System.Web.HttpServerUtility.ExecuteInternal(IHttpHandler handler, TextWriter writer, Boolean preserveForm, Boolean setPreviousPage, VirtualPath path, VirtualPath filePath, String physPath, Exception error, String queryStringOverride)
at System.Web.HttpServerUtility.Execute(IHttpHandler handler, TextWriter writer, Boolean preserveForm, Boolean setPreviousPage)
at System.Web.HttpServerUtility.Execute(IHttpHandler handler, TextWriter writer, Boolean preserveForm)
at System.Web.Mvc.Html.ChildActionExtensions.ActionHelper(HtmlHelper htmlHelper, String actionName, String controllerName, RouteValueDictionary routeValues, TextWriter textWriter)
at System.Web.Mvc.Html.ChildActionExtensions.RenderAction(HtmlHelper htmlHelper, String actionName, String controllerName, RouteValueDictionary routeValues)
at EPiServer.Web.Mvc.Html.IContentDataExtensions.RenderContentData(HtmlHelper html, IContentData contentData, Boolean isContentInContentArea, TemplateModel templateModel, IContentRenderer contentRenderer)
at EPiServer.Web.Mvc.Html.IContentDataExtensions.RenderContentData(HtmlHelper html, IContentData contentData, Boolean isContentInContentArea, String templateTag)
at EPiServer.Web.Mvc.Html.IContentDataExtensions.RenderContentData(HtmlHelper html, IContentData contentData, Boolean isContentInContentArea)
at ASP._Page_Views_Shared_DisplayTemplates_ContentData_cshtml.Execute() in D:\EPiServer\Sites\xxx.Internet\1.65.573.0\Views\Shared\DisplayTemplates\ContentData.cshtml:line 11
at System.Web.WebPages.WebPageBase.ExecutePageHierarchy()
at System.Web.Mvc.WebViewPage.ExecutePageHierarchy()
at System.Web.WebPages.WebPageBase.ExecutePageHierarchy(WebPageContext pageContext, TextWriter writer, WebPageRenderingBase startPage)
at System.Web.Mvc.Html.TemplateHelpers.ActionCacheViewItem.Execute(HtmlHelper html, ViewDataDictionary viewData)
at System.Web.Mvc.Html.TemplateHelpers.ExecuteTemplate(HtmlHelper html, ViewDataDictionary viewData, String templateName, DataBoundControlMode mode, GetViewNamesDelegate getViewNames, GetDefaultActionsDelegate getDefaultActions)
at System.Web.Mvc.Html.TemplateHelpers.TemplateHelper(HtmlHelper html, ModelMetadata metadata, String htmlFieldName, String templateName, DataBoundControlMode mode, Object additionalViewData, ExecuteTemplateDelegate executeTemplate)
at System.Web.Mvc.Html.TemplateHelpers.TemplateHelper(HtmlHelper html, ModelMetadata metadata, String htmlFieldName, String templateName, DataBoundControlMode mode, Object additionalViewData)
at System.Web.Mvc.Html.TemplateHelpers.TemplateFor[TContainer,TValue](HtmlHelper`1 html, Expression`1 expression, String templateName, String htmlFieldName, DataBoundControlMode mode, Object additionalViewData)
at System.Web.Mvc.Html.DisplayExtensions.DisplayFor[TModel,TValue](HtmlHelper`1 html, Expression`1 expression, Object additionalViewData)
at ASP._Page_Views_Shared_DisplayTemplates_ContentArea_cshtml.Execute() in D:\EPiServer\Sites\xxx.Internet\1.65.573.0\Views\Shared\DisplayTemplates\ContentArea.cshtml:line 37
at ASP._Page_Views_Pages_xxxStartSectionIndex_cshtml.Execute() in D:\EPiServer\Sites\xxx.Internet\1.65.573.0\Views\Pages\xxxStartSectionIndex.cshtml:line 83
at System.Web.Mvc.Html.PartialExtensions.Partial(HtmlHelper htmlHelper, String partialViewName, Object model, ViewDataDictionary viewData)
at ASP._Page_Views_Pages_xxxStartIndex_cshtml.b__5_1() in D:\EPiServer\Sites\xxx.Internet\1.65.573.0\Views\Pages\xxxStartIndex.cshtml:line 110
at System.Web.WebPages.WebPageBase.<>c__DisplayClass7.b__5(TextWriter tw)
at System.Web.WebPages.WebPageBase.Write(HelperResult result)
at ASP._Page_Views__MainLayout_cshtml.Execute() in D:\EPiServer\Sites\xxx.Internet\1.65.573.0\Views\_MainLayout.cshtml:line 28
at System.Web.WebPages.WebPageBase.<>c__DisplayClass3.b__2(TextWriter writer)
at System.Web.WebPages.WebPageBase.RenderSurrounding(String partialViewName, Action`1 body)
at System.Web.WebPages.WebPageBase.PopContext()
at System.Web.Mvc.ViewResultBase.ExecuteResult(ControllerContext context)
at System.Web.Mvc.ControllerActionInvoker.InvokeActionResultFilterRecursive(IList`1 filters, Int32 filterIndex, ResultExecutingContext preContext, ControllerContext controllerContext, ActionResult actionResult)
at System.Web.Mvc.ControllerActionInvoker.InvokeActionResultWithFilters(ControllerContext controllerContext, IList`1 filters, ActionResult actionResult)
[Pasting files is not allowed]
#179263
Jun 07, 2017 8:13
