I would suggest to check for CMS.zip in modules\_protected\CMS. It should be present and have correct version.
Thanks Quan, we did that and we do indeed have the correct version up.
It's a puzzle!
Hello all,
Just in case anyone else runs into the same problem - we finally reached the login page by manually deleting every file from Azure and deleting all Episerver related from my project, and then re-installing every Nuget packet again.
Hope this helps someone some day!
Milla
Hello all,
We have a rather urgent issue with our Epi login page, which has disappeared after we've published it to Azure DXC.
We upgraded our project from EPiServer CMS 9.10.2.0 to EPiServer CMS 10.4.3.0.
However after publishing it to Azure DXC, the site is working, but when we try to enter login page (http://inte.alst01masterodq11.alst.episerver.net/Util/login.aspx) it gives '404 Page could not be loaded'.
We are able to get to the login page in our local dev environment, but not in Azure.
Do you think there is something we have missed during the upgrade that could cause the login page 404? We have another new project that works in Azure DXC, so we've compared (configs) these two projects, but there isn’t any differences apart from connectionstrings etc.
Any help is much appreciated!
BR,
Milla
